8 Méthodes pour fixer le problème d'installation de Mises à jour automatique
Ici sont regroupées les astuces et news pour Windows 10.
Messagepar Wullfk » 06 Aoû 2015, 16:03
If you are using Windows 10 and want to change Windows Update download behavior or want to permanently disable or block Windows Update, following methods will definitely help you.
We are listing all possible methods and you can try any of the desired method according to your requirements. All these methods will work in all Windows 10 editions such as Windows 10 Home, Pro, etc:
  • METHOD 1: Customize Windows Update Using Advanced Options Page
  • METHOD 2: Disable Automatic Download of Device Driver Software
  • METHOD 3: Hide Updates Using Official Troubleshooter Tool from Microsoft
  • METHOD 4: Set Your Internet Connection as Metered Connection
  • METHOD 5: Change Windows Update Settings Using Group Policy Editor (gpedit.msc)
  • METHOD 6: Change Windows Update Settings Using Registry Editor (regedit.exe)
  • METHOD 7: Disable Windows Update Using Registry Editor (regedit.exe)
  • METHOD 8: Disable Windows Update Service
Source : AskVG
L'expérience est le nom que l'on donne à ses erreurs ~ Oscar Wilde
Configs Win 10Pro 64Bits / Ubuntu 14.04LTS 32/64Bits
VM Win8.1Pro 32Bits - VM Win10 Pro 32Bits - VM Debian 7.6 Wheezy - VM Win7 Pro 32Bits
Blogs : https:////easy.pc.blog.free.fr OU https:////easy-pc.over-blog.com
Wullfk
Newser
Newser
Retourner vers Astuces et news Windows 10
